сам давно ее использую, на крайняк МХ-2
Отправлено спустя 1 час 37 минут 13 секунд:Прогнал ХВМонитором. Результаты выкладываю.
Может кому чего скажет
под спойлером отчет
► Показать
CPUID HWMonitor Report
Binaries
HWMonitor version 1.4.1.0
Monitoring
Mainboard Model 832C (0x000000E0 - 0x00002318)
LPCIO
Hardware Monitors
Hardware monitor Battery
Voltage 0 16.70 Volts [0x4138] (Current Voltage)
Capacity 0 41440 mWh [0xA1E0] (Designed Capacity)
Capacity 1 38214 mWh [0x9546] (Full Charge Capacity)
Capacity 2 30044 mWh [0x755C] (Current Capacity)
Level 0 8 pc [0x5C] (Wear Level)
Level 1 79 pc [0x4E] (Charge Level)
Hardware monitor D3D
Processors
Number of sockets 1
Number of threads 4
APICs
Socket 0
-- Core 0 (ID 0)
-- Thread 0 0
-- Core 1 (ID 2)
-- Thread 1 2
-- Core 2 (ID 4)
-- Thread 2 4
-- Core 3 (ID 6)
-- Thread 3 6
Timers
ACPI timer 3.580 MHz
Perf timer 10.000 MHz
Sys timer 1.000 KHz
Processors Information
Socket 1 ID = 0
Number of cores 4 (max 4)
Number of threads 4 (max 4)
Manufacturer GenuineIntel
Name Intel Pentium J3710
Codename Braswell
Specification Intel(R) Pentium(R) CPU N3710 @ 1.60GHz
Package (platform ID) Socket 1170 BGA (0x0)
CPUID 6.C.4
Extended CPUID 6.4C
Core Stepping D1
Technology 14 nm
Tjmax 90.0 °C
Core Speed 1599.3 MHz
Multiplier x Bus Speed 20.0 x 80.0 MHz
Base frequency (cores) 80.0 MHz
Base frequency (ext.) 80.0 MHz
Stock frequency 1600 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES
Microcode Revision 0x410
L1 Data cache 4 x 24 KBytes, 6-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 2 x 1024 KBytes, 16-way set associative, 64-byte line size
Max CPUID level 0000000Bh
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 24 KB, 1 thread(s)
Cache descriptor Level 1, I, 32 KB, 1 thread(s)
Cache descriptor Level 2, U, 1 MB, 4 thread(s)
FID/VID Control yes
Max non-turbo ratio 20x
Max turbo ratio 32x
Ratio 1 core 32x
Ratio 2 cores 32x
Ratio 3 cores 32x
Ratio 4 cores 32x
Temperature 0 45 degC (113 degF) (GT)
Temperature 1 52 degC (125 degF) (Core #0)
Temperature 2 51 degC (123 degF) (Core #1)
Temperature 3 44 degC (111 degF) (Core #2)
Temperature 4 55 degC (131 degF) (Core #3)
Power 00 0.00 W (Package)
Power 01 0.00 W (IA Cores)
Clock Speed 0 1599.34 MHz (Core #0)
Clock Speed 1 479.80 MHz (Core #1)
Clock Speed 2 479.80 MHz (Core #2)
Clock Speed 3 479.80 MHz (Core #3)
Core 0 max ratio 32.0 (effective 32.0)
Core 1 max ratio 32.0 (effective 32.0)
Core 2 max ratio 32.0 (effective 32.0)
Core 3 max ratio 32.0 (effective 32.0)
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
CPUID
0x00000000 0x0000000B 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x000406C4 0x00100800 0x43D8E3BF 0xBFEBFBFF
0x00000002 0x61B4A001 0x0000FFC2 0x00000000 0x00000000
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x1C000121 0x0140003F 0x0000003F 0x00000001
0x00000004 0x1C000122 0x01C0003F 0x0000003F 0x00000001
0x00000004 0x1C00C143 0x03C0003F 0x000003FF 0x00000001
0x00000005 0x00000040 0x00000040 0x00000003 0x33000020
0x00000006 0x00000007 0x00000002 0x00000009 0x00000000
0x00000007 0x00000000 0x00002282 0x00000000 0x0C000000
0x00000008 0x00000000 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x07280203 0x00000000 0x00000000 0x00000503
0x0000000B 0x00000001 0x00000001 0x00000100 0x00000000
0x0000000B 0x00000004 0x00000004 0x00000201 0x00000000
0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000101 0x28100800
0x80000002 0x20202020 0x6E492020 0x286C6574 0x50202952
0x80000003 0x69746E65 0x52286D75 0x50432029 0x4E202055
0x80000004 0x30313733 0x20402020 0x30362E31 0x007A4847
0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
0x80000006 0x00000000 0x00000000 0x04008040 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000100
0x80000008 0x00003024 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0x0000003A 0x00000000 0x00000005
MSR 0x00000048 0x00000000 0x00000000
MSR 0x000001A0 0x00000000 0x00850081
MSR 0x0000066C 0x00000000 0x20202020
MSR 0x00000017 0x000000F0 0x90042059
MSR 0x000000CE 0x00000600 0x02001400
MSR 0x000000CD 0x00000000 0x00000004
MSR 0x00000606 0x00000000 0x00000505
MSR 0x00000601 0x00000000 0x00000000
MSR 0x00000610 0x001481D5 0x003880BB
MSR 0x00000611 0x00000000 0x00BE538D
MSR 0x00000639 0x00000000 0x004D63B5
MSR 0x0000019C 0x00000000 0x88230000
MSR 0x000001A2 0x00000000 0x045A0000
MSR 0x00000198 0x00007A00 0x00002059
MSR 0x00000199 0x00000000 0x00002059
CPU Thread 1
APIC ID 2
Topology Processor ID 0, Core ID 2, Thread ID 0
CPUID
0x00000001 0x000406C4 0x02100800 0x43D8E3BF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000001 0x00000100 0x00000002
0x0000000B 0x00000004 0x00000004 0x00000201 0x00000002
MSR 0x0000001B 0x00000000 0xFEE00800
MSR 0x00000611 0x00000000 0x00BE5A58
MSR 0x00000639 0x00000000 0x004D6704
MSR 0x0000019C 0x00000000 0x88240000
CPU Thread 2
APIC ID 4
Topology Processor ID 0, Core ID 4, Thread ID 0
CPUID
0x00000001 0x000406C4 0x04100800 0x43D8E3BF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000001 0x00000100 0x00000004
0x0000000B 0x00000004 0x00000004 0x00000201 0x00000004
MSR 0x000001A0 0x00000000 0x00850089
MSR 0x00000611 0x00000000 0x00BE62F2
MSR 0x00000639 0x00000000 0x004D6AAB
CPU Thread 3
APIC ID 6
Topology Processor ID 0, Core ID 6, Thread ID 0
CPUID
0x00000001 0x000406C4 0x06100800 0x43D8E3BF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000001 0x00000100 0x00000006
0x0000000B 0x00000004 0x00000004 0x00000201 0x00000006
MSR 0x00000611 0x00000000 0x00BE6972
MSR 0x00000639 0x00000000 0x004D6DF6
MSR 0x0000019C 0x00000000 0x88210000
Storage
Drive 0
Name TOSHIBA MQ01ABF050
Revision AM0P4C
Serial 57SFT6CNT
Capacity 465.8 GB
Type Fixed
Bus Type SATA (11)
Rotation speed 5400 RPM
Features SMART
Volume c:\, 140.0 GBytes (80.8 percent available)
Volume d:\, 325.1 GBytes (99.8 percent available)
USB Devices
USB Device Универсальный USB-концентратор, class=0x09, subclass=0x00, vendor=0x05E3, product=0x0608
USB Device Составное USB устройство, class=0xEF, subclass=0x02, vendor=0x05C8, product=0x03AC
USB Device Realtek Bluetooth 4.0 Adapter, class=0xE0, subclass=0x01, vendor=0x0BDA, product=0xB008
Graphic APIs
API D3D
API Intel I/O
Display Adapters
Display adapter 0
ID 0x4000000
Name Intel(R) HD Graphics
Board Manufacturer Hewlett-Packard
PCI device bus 0 (0x0), device 2 (0x2), function 0 (0x0)
Vendor ID 0x8086 (0x103C)
Model ID 0x22B1 (0x832C)
Revision ID 0x35
Performance Level 0
Monitor 0
Model ()
ID BOE06A5
Serial
Manufacturing Date Week 1, Year 2015
Size 15.3 inches
Max Resolution 1366 x 768 @ 59 Hz
Horizontal Freq. Range 0-0 kHz
Vertical Freq. Range 0-0 Hz
Max Pixel Clock 0 MHz
Gamma Factor 2.2
ACPI
ACPI Tree
Отправлено спустя 19 минут 1 секунду:Какие еще будут предложения?
Препарировать? Лоботомию? Или пока на реанимацию?
